Just want everyone to know if you purchase an LED tailaight from 58cycle there is a possibility that you get a bad wired light. I installed mine the other day and it didnt turn on. Istarted diagnosing it and come to find out the wiring inside the light was mixed up. The left prong being the ground, middle is the running light and right being the brake. The harness has a black(ground) blue(running) and red(brake). The prongs on the light itself were switched the brake and running light were backwards. All you have to do is cut your running and brake wire on the harness and switch them to make it work. Not sure if I just got a runt light that someone made a mistake building or if all thier lights from that distributor are like that. Oh almost forgot the harness is upside down also so plug it in opposite the way its suppossed to. It was the smoked set so if anyone has anymore problems let me know and I can post some pics.
Custom fender eliminator, Flies out, mirrors removed w/rear camera, two brothers exhuast, All 4 DDM HIDs 55w 10k, all smoked signals w/LEDs
You can't run an army without profanity; and it has to be eloquent
profanity. An army without profanity couldn't fight its way out of a
piss-soaked paper bag. ... GEN George S. Patton
